Standard Headlight Bulbs
Just after getting the bike I accidentally left the parking lights on. They were on for about 7 hours. It did crank but barely.
Almost through with my Eastern Beaver relay install. Only thing left is to run the power line back to the battery and install the fuse.
Being stupid as to electricity, I wired my possition lights back up with the second (unused) connector. When I cut the first one off to solder the yellow and white leads, I cut the position light wires off at the connection. I used the sheathing on the original conn to insulate the two wires over to the right headlamp assy. I then installed the eastern beaver H4 conn, then solderedd the yellow and white wire i brought over to the right one using the original harness sheathing. I just pulled the other wires out.
So, my left connector is for the lights and the right side conn is only going to work my position lights.
Atleast, I hope so.lolIt's late and I don't dwant to know if there is a problem yet. I'll wait till in the morning and complete it.
Seemed simple enough following these directions. Only question will be the parking lights.
I'll let you know tomorrow if it works.
BTW, is there any reason you can't just pull the yellow and white wire out of the conn with needle nose pliers instead of cutting and taping up the wires? If someone thinks this is a problem, I hope you post it soon.lol
Later
Sounds like you are almost there. Good luck on the first test.
btw, the bars fit great. left them black for now. a big Thanks!
relay kit and keyless ignition
has anyone ran the relay kit alongside the keyless ignition , any special instructions , here is what i have done , installed keyless ignition about two months ago, now today i was installing a pc8 fuse panel with relay, dual headlight relay kit with low beam cut out, installed pc8 getting power to fuse box thats all good, conected relay kit to the fuse box installed fuse , hit my remote and no headlights, no guge sweep or nothing , my relay on my remote is closing so i know thats working , im hot going to the headlight relays but the relays dont seem to be closing , did i miss anything , oh yeah the two wires for the lowbeam cutout switch i just wired them together for trouble shooting, what do you need going to the relays to get them too shut and power the headlights. any ideas will be tried , figured it out , i screwed up my remote unit to power my relay when i hooked it up the first time ,, i aint no electrician so it took me a few hours . well for now i will finish the install with a switch till i can get a new remote unit , im thirsty i will finish tommorow
One final note, make sure that you thank your trusty helper. A small sample of treats will do. They are not hard to please.
Old timers say having a black cat is lucky. I dont care for cats.[/QUOTE]
I love cats!!! But I could not eat a whole one
