Spy shots new rocket
I purchased the black Triumph tear drop mirrors years ago. After installation the vibration on the mirrors was so bad I could not use them. I tried different type of methods to totally remove the vibration or reduce it. Nothing I did would work. So I decided to purchase bar end mirrors. NO VIBRATION and now have mirrors I can use. I was paranoid that the vibration was going to be worse with the bar end mirrors but that was not the case. Funny how that worked out.
Nice to hear there are bar end mirrors which don't vibrate. Question: which brand did you install ?
Rizoma. They are expensive but they are a high quality set up. They have a special glass that is kind of blue ..anti glare.
Rizoma Reverse Retro Universal Mirror BS070 - SoloMotoParts.com
Thanks !:) Just one question left,as I did have a close look at these mirrors at the Rizoma site, the mirror bracket is fixed on a flat bar end. However, the bar end weights of the Rlll are not flat, doesn't that give an issue for attaching the mirrors to the weights ?
Not sure if I'm a following you correctly on that question.
There are adaptors from Rizoma you have to purchase in order to mount the mirrors to the existing bar end weights. The adaptors fit flat against the weights... then mount the mirrors on the adaptors.
When I get some time I will try to find the box and give you the correct part number for the adaptors.
thanks, I'm looking forward to it.:)
Write your reply...
