I think all vehicle odos are designed to read fast for speed ticket avoidance reasons. KTMs have always been some of the most over-optimistic. The speed of wheel rotation on them is read by a sensor on the inside of the brake calipre reading a slotted ring bolted to the brake disc. You used to be able to buy aftermarket rings with an amended slot pattern that gave a true reading. Whether you can still do that with the plethora of extra electronic gizmos on the latest bikes I don't know.
No - '06 zx10r was spot on, my '10 Aprilia v4r was spot on, and my '16 HD sportser is spot on. All checked with GPS. For a 23K (usd) bike, I expected more
My meaning was that speedometers today not being accurate is nonsense.
If that is the case, all the 'Your speed' indicators placed on the roadside, especially in built up areas such as towns, must be incorrect.
I have been doing what my speedo says 50 kph when entering a 50kph area and the speed indicator on the roadside tells me im doing considerably less.
I'm certain this is the case in many countries not just here.
This is obvious when on my motorcycle but not in my Car....so i do not think it's nonsense as you suggest.
Oh boy, second try...I mean that it is stupid that manufacturers are making speedometers that are NOT accurate. 🤓👍
The speedometers aren’t defective. Their calibrations are just off. Intentionally it seems, at least for the previous and current Rocket generations. Maybe for all Triumphs?
Now you mention it, my Harley LRS was spot-on. But it's the only vehicle I've ever had, which I've checked against sat-nav, that was. My cars, vans, pickups have always read 5-10% high and so have all my bikes - except the Harley. All my KTMs have been the furthest out at over 10%.
Personally I don't worry about it. In speed limits I ride or drive to the speedo, not the sat-nav. If they were reading low it would be a different matter.
In the United States, there is no regulation regarding accuracy of speedometers. The threat of civil action (lawsuits) ensures that manufacturers strive for speedometers that are very accurate or, to save money and comply with European mandates, read high. This is why American vehicles meant for the U.S. market will typically have very accurate speedometers. I know all of mine have.
In the EU and other European countries, regulations require that speedometers never read below the true speed of the vehicle. For example, the UN/ECE Regulation 39 mandates that speedometers read as follows: 0 ≤ (V1 – V2) ≤ 0.1(V2) + 8 km/h, where V1 is the displayed speed and V2 is the true speed, that the indicated speed is not below the true speed, and that test instrumentation to determine the true speed be accurate to within 0.5%. Test speeds vary based on the vehicle's maximum speed (vMax). For the Rocket 3, with a vMax in the highest category of > 150 km/h, the test speeds are 40, 80, and 120 km/h.
To simplify, this means the as-tested difference between the indicated speed and the true speed must be less than or equal to 10% of the true speed plus 4 km/h, and that the indicated speed be greater than the true speed. But since the test equipment can be up to 0.5% inaccurate, manufacturers need to account for the 0.5% inaccuracy in the speedometer's calibration to ensure they pass. Some examples:
True speed 100 km/h = 0.1(100) + 8 = 14 km/h
Speedometer must read between 100 and 118 km/h.
But since the test equipment can be off from the true speed by 0.5%, the speedometer will be engineered to read somewhere between 100.5 and 117.5 km/h
This is a real-world 0.5% through 17.5% inaccurately high reading.
Using the official test speeds from the regulation:
At 40 km/h, we're looking at a speedometer engineered to read anywhere from 40.2 through 51.8 km/h, or 0.5% through 29.5% high, with 15% being mid-range.
At 80 km/h, we're looking at a speedometer engineered to read anywhere from 80.4 through 95.6 km/h, or 0.5% through 19.5% high, with 10% being mid-range.
At 120 km/h, we're looking at a speedometer engineered to read anywhere from 120.6 through 139.4 km/h, or 0.5% through 16.2% high, with 8% being mid-range.
8% appears to give them a good buffer that complies with the highest test speed, which is right where the Rocket (and most other European vehicles I've owned) sits. Weirdly, my Tiger 1200 GT Pro only reads 3% high.
Correction to earlier, category L3 vehicles (includes the Rocket) are +8 km/h, not +4 km/h. EUR-Lex - 42018X1857 - EN - EUR-Lex
Write your reply...
