Brother, working on my own Trans issues now. Read your ordeal and learned a lot. These alternative bolts you found. You say 14 are needed, but the manual says to remove and discard bolts 11-35 (24). Page 5.6 step 5 on disassembly. What am I missing??
Most of the time, Triumph says to replace the bolts because they come with loctite on them. I guess their mechanic's can't squirt the old bolts with new loctite
I reused my case bolts. I did replace the main bearing ladder bolts, but Warp 9.9 pointed out that that is not required on the early models according the manual.
This forum has been a wealth of information. It’s nice to get input from people who have been down this road. I have threadlocker and will easily apply the required amount to make these old bolts hold tight
Progress! Finally I was able to close up my engine cases, feels good.
This step is a timed test!! Have all your tools ready, manual open, and load the different length bolts before fitting the lower case. You’ve got about 30 minutes!
