I couldn't be any more pro-Dobeck. Just love it. It is about as difficult as installing a GIPro. In other words, not hard at all. It is even easier to set. Pure simple. If you want a bike that you can do modifications and not have to beat a trail to the local dyno shop, it is the way to go. If you are racing at the track, it isn't the way to go. A note: One trip to the dyno would buy several Dobeck's.
If you like to do fuel/air and other numbers, and don't mind spending a fortune going back and forth to the tuner's dyno, use the TuneEcu, Tuneboy, and PC whatever. If you want to be able to ride immediately after you change exhaust pipes or make a change to your intake, get a Dobeck and it will run like a champ.
It might work OK but I probably would be hesitant to recommend a Dobeck if your bike's air is force fed.
