So another early YR rocket speedometer question
Rocketeer4life
Built like a rock
Pennsylvania
2005 Rocket 3
So after i thought i fried my enttire speedometer gauge cluster. turns out the road speed sensor actually went bad. replaced ans speedo is readding perfectly, along with odometer readings.. my major concern is if my check engine indicator/ low oil/ temp indicator are working properly? dont wanna run with not knowing!
after disconnecting harness plug from speedo-then reconnecting-then givin power back 2 the battery, speedo did read error codes and could connect to tune ecu to clear codes.
cannot connect and perform tests or adjustments?....heres what im workin with:)
