The new Rocket's side stand bracket bolts to the engine with 3-off M10 bolts. Minimum grade 8.8, I would think. No way that is going to break the casing before the side stand pin fails. The pin will be a BS970 grade EN19 (4140), EN24 (4340), or similar, plated. No way that will snap before the side stand does. Any manufacturer using an aluminium side stand must have brass b4lls or is using a good grade for that; either 6061 or 7075. That should bend somewhat, warning its owner, before it breaks. But I do appreciate that people can probably break anything if they try hard enough.
