Mittzy
The Hooligan - Just Doing Stuff
- Joined
- Aug 29, 2011
- Messages
- 8,545
- Location
- Brisbane, Australia
- Ride
- 2020 TFC #385, 2014 R3 Roadster 230hp (BRUTUS)
I've been searching for them today to no avail. One that I ran across used the pin that is in between the two cable ends but the picture wasn't that detailed.
After thinking more about your setup, it seems unlikely that the hoop would ever slide up the return cable so I retract my comment. I will probably do the same.
Ordered my kit and VSS thingy today.
At one stage I did make a washer with a conecter on the end to replace the stainless steel washer on the conecting linkage, sort of worked ok - BUT stiffened the whole throttle and would not return throttle to idle position when releasing your right hand grip - may have loosened up eventually I dont know
