Tbirdgirl
Watch out for the whip...
Wyoming
2011 R3 Roadster
Hi guys, just thought I'd post that I joined the Rocketeers Club. Third Triumph, first Rocket. So far, great bike, nimble for such a beast, but aftermarket support is ****. Trying to fit LED turn signals and a screen is proving to be difficult. I will keep trying, though.
Welcome to the club from sunny Southern California! Are you still going to keep the TBird? What kind of LED signals are you trying to fit?
I'm just trying to install 1156 LED bulb replacements. Putting load balancers across didn't work, electronic flasher didn't work. The left front signal flashes once and nothing more.
Can't help you there, but I'm sure someone will be along soon to help you out. @DEcosse will certainly have a solution for you.
Check behind the reflector inside the signal housing, the hot wire need to go to the center (bottom) post, the ground wire need to go to the side. All 4 of mine were wrong from factory. Sounds like yours are as well.
