Roadster Headlight not impressed
I have Harley Genuine Daymakers for the past 3 years, after spending quite a bit of time adjusting them I am very pleased. I can tell you they cost me a lot more then the ones you have found but look exactly the same.
I ordered the Hella's, should have them by Wed and that will be a quick switch so I should have a good idea how they are by the weekend.
Got the Hella’s, drilled the hole for the parking light and mounted them up in about 20 min. Just did the adjustment tonight in the dark and wow, the high and the low beam are right where they are supposed to be!!! Lord, its a miracle! The pattern is even better, wider in the low beam setting than stock. Problem solved.
