Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,940
- Location
- Ride
Roadster version:
Front Footrests & Mountings - Roadster - Triumph ROCKET III, CLASSIC & ROADSTER | Triumph ROCKET III, CLASSIC & ROADSTER Front Footrests & Mountings - Roadster supplied next day (UK only) by Fowlers Parts
# Part Stock RRP Basket
1 Foot Control Mtg Assy, RHS T2087000 £147.98 inc. VAT
2 Foot Control Mtg Assy, LHS T2087001 £143.66 inc. VAT
3 Footrest Assy, RHF T2083023 £62.05 inc. VAT
4 Footrest Assy, LHF T2083026 £62.05 inc. VAT
5 Rubber, Footrest T2083025 £8.36 inc. VAT
6 Screw, Hex, Pan Hd, M5 X 16 T3330173 £2.51 inc. VAT
7 Bank Angle Peg T2081409 £6.94 inc. VAT
8 Pivot pin T2080547 £3.35 inc. VAT
9 Return Spring, Footrest T2080819 £3.23 inc. VAT
10 Circlip, Ext 8 X 0.89 T3500207 £1.46 inc. VAT
11 Bolt, HHF, Lghtd, M8 x 20, Enc T3205457 £0.79 inc. VAT
Gear Sel. Pedal-Rocket III Roadster only - Triumph ROCKET III, CLASSIC & ROADSTER | Triumph ROCKET III, CLASSIC & ROADSTER Gear Sel. Pedal-Rocket III Roadster only supplied next day (UK only) by Fowlers Parts
# Part Stock RRP
1 Assy, Gear Pedal T2089660 £100.72 inc. VAT
2 Rubber, Gearchange Pedal T2080766 £4.72 inc. VAT
3 Pin, Gearchange T2080697 £4.98 inc. VAT
4 Assy, Gear Linkage T2089661 £61.88inc. VAT
5 Ball Joint Assy, RH Thread T2080882 NO LONGER AVAIL. £11.71 inc. VAT
6 Nut, M6, LH, Black T3350307 £0.80 inc. VAT
7 Rod, Gearchange T2080884 £13.81 inc. VAT
8 Nut, M6, Black T3350306 £0.77 inc. VAT
9 Ball Joint Assy, LH Thread T2080883 £12.12 inc. VAT
10 Washer, 6.4 x 11.0 x 1.6, Black T3350900 £0.60 inc. VAT
11 Clamp, Linkage T2087777 £30.55 inc. VAT
12 SCREW CAP/HD M6X1 0X25 SLV T3050334 Replaces T3050332 £0.77 inc. VAT
13 Bolt, Shld, M8, Slv Enc T3331614 Replaces T3331612 £5.17 inc. VAT
14 Domenut, Locking, M6 T3350088 £0.89 inc. VAT
Rear Brake Master Cylinder, Reservoir & Pedal - Roadster - Triumph ROCKET III, CLASSIC & ROADSTER | Triumph ROCKET III, CLASSIC & ROADSTER Rear Brake Master Cylinder, Reservoir & Pedal - Roadster supplied next day (UK only) by Fowlers Parts
# Part Stock RRP
1 M/Cyl & Reservoir Assy T2025202 £150.89 inc. VAT
2 Connector Set T2022108 £13.37 inc. VAT
3 Piston Set, Rear Master Cylinder T2022110 £35.15 inc. VAT
4 Circlip, M’cyl, Rear T2020472 £1.40 inc. VAT
5 Assy, Pushrod T2025009 £21.83 inc. VAT
6 RESERVOIR SQUARE TANK ASSY T2024080 Replaces T2023191 £23.95 inc. VAT
7 Reservoir Hose Clip T2023188 £1.81 inc. VAT
8 HOSE, RESERVOIR, M/CYL REAR T2022130 £17.42 inc. VAT
9 Brake Pedal Assy T2025207 £94.22 inc. VAT
10 Bolt, Shld, M8, Slv Enc T3331614 Replaces T3331612 £5.17 inc. VAT
11 Spring, Brake Lever Return T2020274 £5.06 inc. VAT
12 Pin, Clevis, 8 x 13.7 T3000301 £2.17 inc. VAT
13 Clip, 8mm, Clevis Pin T3000302 £3.12 inc. VAT
14 Rubber, Brake Pedal T2025001 £20.48 inc. VAT
15 Screw, But/Hd, Skt, M8 x 25 T3335012 £4.30 inc. VAT
16 Cover, Master Cylinder T2025103 £26.99 inc. VAT
17 Screw, Tx, Pan/HD, M6 x 16, Slv T3330334 £1.37 inc. VAT
18 Locknut, Flanged, M6 x 1.0 T3350003 £0.48 inc. VAT
19 Cover, Master Cyl Reservoir T2025102 £27.42 inc. VAT
20 Heelguard, RH T2025101 £29.42 inc. VAT
21 Screw, Btn Hd, M8 x 12, Slv T3331625 £0.88 inc. VAT
22 WASHER M8 BS4320 FORM B SS T3550277 Replaces T3550260 £0.50 inc. VAT
23 Washer, 15.2 x 10 x 1, Plated T3550229 £0.58 inc. VAT
24 Bolt, Banjo, M10 x 21 T3250125 £3.61 inc. VAT
25 Brake Line Assy, Hard T2025204 £15.07 inc. VAT
26 Guide, Brake Hose T2020269 £3.66 inc. VAT
27 Adaptor, In-Line, Brake Switch T2025005 £11.72 inc. VAT
28 Screw, Tx, Pan/HD, M6 x 16, Slv T3330334 £1.37 inc. VAT
# Part Stock RRP
# Part Stock RRP
