Allan S
Simple African lad with a Rocket
I bumped a connector off of its spade when removing the stand that holds the tank up. Not noticing it, I started the engine and it ran. I put the tank down again, started the engine and rode off. I noticed the check engine yellow light was on so I lifted the tank again and found the loose wire. I connected it again with a healthy click and the engine runs fine. I dont have Tune ECU and the shop told me to bring it in and they would reset it for me. The shop is 50 miles away and I saw a post on the forum that the light might reset on its own if the problem is cleared after a certain number of ignition cycles. Can anyone tell me how many (approximately) and if a cycle includes starting the engine or just waiting for the gauges to settle. I attached a picture of the connector ( the one on the front)
that I disturbed if that helps?
