Replacing Negative Battery Cable
So if i can ask. what is this of doubling up negative cables? As in to literally route a second cable along side the original and bolt over top? If so im all for it as im literally right there puttin a new engine in!! Whats the perks of this exactly?
Also anyone know if i can just use the 05 starter solenoid plug from the harness to my 2014 starter?
I used a second neg wire and just went from bat to starter bolt. Seems to work and doubles the load it can carry.
I think my old cable was having problems with the connectors because it worked better.
Also went with the heavy duty starter
and that helped.
and that helped.
Oh ok i see then. Well im definetly gettin in on that! Thanks for the reply then.
Yeah fyi, I was able to jus use the 05 starter solenoid wire connection. An exact fit to said newer engine
