RENEWING FORK OIL
If you remove the wheel you will find an allen screw under each fork leg. Remove it and the oil will drain out. an impact gun will help to re-install them. If you are really fussy you could replace the aluminum washers. HTH
The fork caps are not under spring pressure.
I'm not fully understanding. Are you saying that this is all that is need to drain the forks?
