Here you go Canberra here is mine, i found the fiber washer can't take the heat that were supplied they burn up so i got some mice fiber ones made of glass that work fine
I'd doubt it would stop the 'slow roasted leg' .. still a lot of exposed header pipe there .. I could be wrong , but I don't think so .. unless your bikes run a ****load cooler than mine does.
Mizzy its a lot better than with it about the same as my mates x deavil
when moving works well when at the lights can feel a bit of heat but definitely much better
The fibre washer won't take the heat as Pete said. I'm guessing Ric has changed it a bit since mine cause that allows the screw to back out and on mine he tapped the holes right thru into the pipe. Hard to make a heat comparison, but in Sydney traffic in summer it wasn't excessive. Yep that's Ruzzles bike, took him along, someone had to do the work!!!!
