Eisenfarn
- Joined
- Apr 22, 2024
- Messages
- 27
- Ride
- Kawasaki ZZr14
I have been having an intermittent problem with the rear right indicator, the amber bulb warning lights up on the panel and the front right indicator flashes at twice the usual speed. To me this is usually an indication of a bad earth on the indicator lamp itself. Checked all the wiring within the rear light unit, which seemed OK, but after riding for a few minutes, once I use the right indicator, same fault. I bought a used complete rear cluster and swapped out one of the indicators, few days down the line this seems to have cured the problem,.
My question is this, is it possible to open up an indicator non destructively?, I read somewhere, which I can't currently find, that the main problem is a dry joint on a small circuit board within the indicator itself. I can't see a way to open it up without using brute force, which would defeat the objective a bit
. Anybody done this?
Ta
Ta
