Lean doesn't always give you better milage efficient does.
absolutely 100 percent behind you there....it's the same for any motor isn't it....An outboard motor with the correct prop is an example...smooth...good thrust and efficient.
There is something very satisfying about a well tuned smooth running motor...especially on a bike under you.
how do I find the tune please
Tripx, do the canned tune for now as a short term option. Once you find the pipes you have been looking for, drop it into Neville Lush at Victor Harbor for a dynu, you will not believe the differethe will make on that bike. A canned tune will only get you in the ballpark, nothing more
Cheers mate got cable on the way for tuneecu. pipes are most likely going with the standard 3pipes.
Write your reply...
