I fitted the ramair filter at 28000km with the crankcase foam filter. I don’t baby the bike and often use full throttle in top gear when on group runs. After getting home from a recent run I could could see a faint vapour at the back of the motor. The motor has done 40,000km and Is due for its 10,000m (mobil 1) oil change. I’m a little disappointed it’s showimg signs of blowby this early but as one famous Aussie once said “such is life”.
I used a 3/4” hole saw to drill a hole in the opposite position to the air sensor on the Ramair and machined up a two piece nylon fitting that I glued together with loctite “all plastic” polypropylene glue to form an elbow.
I based the elbow fitting dimensions on the ramair air sensor and allowed for a 1/2” inside diameter hose.
Then connected the crankcase breather to the ramair filter by routing up the rear of the motor and forward under the tank.
Photos attached.
Then told the missus the motor was buggered and we need to start saving for an engine rebuild with upgraded Ho to make it stronger
