that was the problem i had with the GT, but if you have a really good pull, and clutch in just before the speed limiter kicks in the momentum will take you fasterZx14r - when it was stock I hit the 299km/h limiter. Since then I've hit 310 indicated.
2020 rocket - I hit the limiter and the speedo said 237.
After installing a full Brock's titanium exhaust on my zx14 I flashed the bike, which removed the speed limiter, making it possible to splat myself even more thoroughly.that was the problem i had with the GT, but if you have a really good pull, and clutch in just before the speed limiter kicks in the momentum will take you faster
Remove change,wallet from pockets helps too!that was the problem i had with the GT, but if you have a really good pull, and clutch in just before the speed limiter kicks in the momentum will take you faster
My gt3 tops out at 240kmhspeechless
I hope you get every thrill out of every one of those km/h.My gt3 tops out at 240kmh
Ya have only done once just needed to know how quick it is, normally just cruise & enjoy the rideI hope you get every thrill out of every one of those km/h.
