R3T Tire Replacement
The Exedra Maxes that I put on were 71V front and 77V for the rear. I don't have that many miles on them, yet, but overall they are superb. Marty
AHA! It appears you are correct. I got my info on the load rating from SWMOTOTIRE. Evidently they used the rating from the front tire for the rear. Checking Bridgestone's site the 180 70 R16 is indeed rated at 77. That would make the pair the same as the Avon Cobras.
Thanks Marty!!
You're right. Big difference though is the Exedra 240 rear is load rated at 86. The load chart I've got ends at 80 which corresponds to 992 lbs, so that fat rear tire can easily carry the load. The 180 on the R3T is the problem.
yeah I know that is why I mentioned it to Daddyrabit I dont think he realised that you guys were discussing fittment to a Touring and I noted in his avatar he had a Classic
The weight is shared over two wheels so the load on each tyre is roughly half the weight of the bike. Reckon you're safe with all of the listed brands from that perspective.
Yep! Your right Hanso! I overlooked the "T". Should be fine on my Classic! Thanks for looking out for this old DumbArse!
I plan to use them next.......
That's a very good point about the tire load rating. I overlooked the point about the rating applying to a single tire of a two tire setup. So you can effectively double the load rating to get the amount of weight the tires are actually rated to carry.
Thus a set of 71 rated tires should be safe up to 1522 lbs. If that's the case, there's quite a safety factor built in to the OEM specs. BTW, I figure that with me, gear, and fluids in the bike, its running about 1060 lbs. ****!!
I'm on my 2nd set of Exedra Max tires on my R3T. 7700 on first rear and 13500 on front. They work great and the price can't be beat.
I got 5100 miles on my metz rear and 7000 on the metz front.
Interesting mileage stats. I tend to always replace them as a set, probably more out of avoiding the hassle of doing it twice. Checking my tires yesterday I noticed that the front tire has worn faster than the rear. I'm getting close to the wear bars on the front and the rear has a fair amount of tread left. Not sure why, nor do I remember if the Avons wore the same or not. Obviously, more burn outs are in order.
Interesting, I got almost 2 fronts to a rear Metz, hard to say exactly, as I seemed to have a nail magnet in the front tire the first year, but guessing similar to mport, about 5000 rear, 8000 front. Avons seem to be wearing much more evenly, near 6000 and both got some life left. I have a brand new set of Metz in the barn I picked up for $100 for the pair from a guy who totaled his R3T before he got to mount them. Once they are done, I will definitely try the Exedra Max.
Just ordered the Avon Front and Exedra Back from Chaparral...only place I found that ships to APO, but had about the best price to boot!
