Short answer: yes - to a point.
It's not nice to fool Mother Nature they say.
You'll get whatever performance your setup will allow, and if your only reference is your current ride, you should notice a substantial boost in your seat.
Thanks for the short answer...and yes Blue is my only reference... So this news is good.
Ladies and gents,
I have had more than a few calls about Touring model performance. This should help out more than a few of you.
The Touring models are the same except for the exhaust and ECU calibration. BOTH are very restricted.The ECU controls the secondary throttles and actually closes them at higher rpm and higher gears. In the exhaust, the header is the same, but the box after the header is very restrictive. Slip-ons (TORS and D&D) really don't do much except for sound.
Neither do air filters under the seat. Triple K&N RU-2780 filters make a bit more from 4000-5500 rpm, but have the same peak power output as the stock air filter. The stock intake plenum and ducting actually makes more torque under 3000 rpm than triple RU-2780 filters under the bearclaw. It is not until you go to a full exhaust system that the RU-2780 filters make a difference.
A stock R3T or one with a slip-on exhaust tends to make ~86 hp on my dyno (~ 13% lower than a Dynojet), and 130-131 ft-lb of torque. Simply re-calibrating the ECU (mapping) tends to result in 115-117 hp, and 140-142 ft-lb of torque. A very nice improvement.
Attached is a "tune" for stock and slip-on exhaust R3T models, as well as a graph of output differences. Dashed lines are torque. Red is an R3T with TORS and stock air filter. Yellow is after tuning. This resulted in 43+ mpg cruising at 70 mph on 87 octane fuel. Speedo corrected for stock tire. Speed limiter raised. Ignition timing improved in lower gears. ENJOY!
You can also find this map on Tom Hamburg's TuneECU.com site under the custom Triumph tunes section.
NEW TUNE ECU PROBLEM!
How am I supposed to be able to sleep within 2 hours after the ADRENALINE RUSH of riding my 2011 R3T with a Paul Bryant free flow crossover installed and a derestricted (slightly tweaked) stock map from HansO!
WOW! THANK YOU ALL who helped with various posts and threads for educating me in how to get this done myself! A special thank you shout out for my 20 year son Tristan! Thanks again kid...VERY pleased and proud of the work that wouldn't have been done without your help!
I seriously have to now plan on when riding is practical with my night shift sleep schedule... with WAY too much fun I still can't seem to get this bug-eating grin off my face!
I hope to Dyno results to compare the before and after and share in a thread within a couple of weeks.
YOU GUYS ROCK...MY ROCKET!
THANK YOU ALL AGAIN!
Ladies and gents,
Thanks for the great info!
I ran my after redistricting tune and free flow crossover pipe installed dyno....as expected a 30 hp jump and 5 ft/lbs torque. I was able to do the work myself with my Son on the laptop, and the forum's expert advice!
I am thrilled with the results! Thanks again
Free4all don't be afraid to get the TORs or D&D slip-ons. THEY SOUND GREAT and are not loud or obnoxious. Either of them will add a good bit more to that bug eating grin. Especially the D&D.
I have ALMOST pulled the trigger on the DandDs several times...that is what I will end up with eventually...baby steps for me and my mods to 'Blue'! Air horn and accent LEDs are working their way to the top of my modification list next I believe...
Now that I know what 30 more hp feels like...I can see what the appeal is for more,More,MORE!
Can you or somebody else send me the map to get these kinds of numbers out of my stock touring setup. Please.
Thanks
