R3T derestricting
Wayne, is there a replacement "Y" pipe for the Touring Model? If so can you post sources? Thanks much for all your research and work!!
Power-Tripp, what is the ETA on your new exhaust and intake for the R3T? I wouldn't want to buy off-the-shelf parts and soon thereafter learn that you have introduced a game-changing product.
Bob, I don't think map 20368 is the map that power tripp is writing about in the first post in this thread (but I'm not sure as s was a difficult process for me). I think powertripp's map is NOT available on the tune ecu website and that his new map is only available, as he wrote, in the CUSTOM triumph tune section of tomhamburg.net or at the end of powertripps message. I made the mistake of downloading the map from tune ecu to start off my wrangling with this process.
I need someone here in Florida who can help me achieve this result. I am not technically adept enough to try it myself.
I have a stock set up, except for TORs and an underseat K&N. As I read this, there's a tune that will get me somewhere around 115 HP and 140 ft-lbs, WITH 43mpg @ 70 mph. This seems impossible to me. I barely get 33 mpg now at 70 MPH and the bike runs lean as it is - 43 MPG is a pipe dream for me. While it's true that a lot of my cruising takes place at 80-85 MPH, I can't believe there wouldn't be a substantial improvement there also.
Seriously, is there anyone down here with Tune ECU experience and a cable who could help me accomplish these goals?
If so, let me hear from you.
Thanks.
You don't need anybody with you to do it. If you buy the correct cable you'll be set if you have someone knowledgeable on the phone to walk you through it. I'd help but I needed my son to get me through it. The recommended cable is on Amazon (USB Cable for triumph tune ecu-it has a blue plug and the wire is covered in clear plastic). If you want your bike to scream try tune ecu #20258 on the www.tuneecu.com website.
How about if your well-meaning service guy installed the latest software on the bike during the last service - didn't Triumph put in some anti-change functionality in there to prevent people doing what they want to their own property? Edit: oh, ok, did some searching and this apparently only applies to some 2012-2013 or up bikes from Triumph. My 2010 R3T should be fine, I guess.
This might be of some help......
This video is actually the video that I used to do my first tune. If someone can't do their first tune by using this video then they don't need to be tuning or fooling around with their motorcycle period. lol
The computer part doesn't really worry me, it's the possibility of "omg my engine exploded and landed two miles thataway" part that has me worried. :-D Cable ordered. It seems silly to not add 30 more horses, more torque and improve fuel efficiency when all it takes is a few mouse clicks.
Reactions: ski
I installed power-tripps tune on my 08 R3T and can definitely feel the power difference. My gas mileage went down a bit. Around town low 30s; highway high 30s. Before I could reach nearly 40s
Using fuel without ethanol, however, I can come close to 40mpg at the higher expense of fuel.
