R3R Love At First Sight!
Welcome and congrats on the bike.
We've been discussing a common problem on all dual headlight bikes Triumph has yet to fix, you should be aware of it ASAP.
The ignition switch carries too much amperage and melts the solder points over time. Installing a Headlight Relay Bypass Kit is strongly recommended.
Easter Beaver.com makes a kit specifically for the R3 and you should look into it. Use the search box here on the site to read past and current discussions on the subject before it embarrasses you in front of your Hardly buds. ;)
Thanks Hellfire, you're timing is perfect I've been reading about that issue just 10 minutes ago. I will order the EB kit right away, much appreciated!
Be sure you get the longer lead kit for R3 so the relays will go under the tank rather than headlight buckets. Also, there is an option for "Low beam cut off", it will be a handy option later on for turning off the headlights for cold weather starting and while doing work on the bike. You don't have to install a switch for it right away, you can just jumper the extra lead and leave it under the tank for now until you need it later. It's a cheap option and can be very handy, I use it to shut off the lights for extra battery charging ability. (and for being sneaky ;))
Oh yeah, and since it's just a low beam cut off you can ride around with the lights off if you want and have the ability to turn them on quickly just by hitting the high beams.
Welcome!
I had to wait four months to get my Roadster. You made it sound like a walk in park. lol
Oh the Matte black is the faster of the Roadsters by the way :D
G'day from tropical North Queensland in Oz.
I just keep loving my Rocket more and more. You'll never regret the decision to make the change.
Mully, the matte one only seems faster coz you're riding it the way you used to ride that zx10. Do you still have rubber on that back tyre?
I believe you remember I went to the dark side because of a nail in motorcycle tyre. But looking at the DS tire yesterday I can tell Im wearing it quicker than what I thought I was... need to slow down I guess so it will last a little longer. :(
WELCOME TO THE ROCKET WORLD they are rather addictive I test rode one it took me 3 years before I could afford one but it was worth the wait.
ooh while you are under the tank doing the relay upgrade rip out all that plumbing to the airbox remove the secondary throttles put on some K&N's make her breathe then hang on... when you do that then you will know why we never stop grinning oh if you want more piss the original exhaust of and really friggin hang on:D:D:D
Thanks for the welcome hanso!
I'm going to take your advice as soon as I get back from a 6700 mile cross country trip I'm making at the end of the month, unfortunately it won't be on the Rocket though because it's not ready yet (ignition, bags, etc) so I'll be riding the Harley.
Ride Safe!
