trapper
.040 Over
I have read a lot of stuff on all the forms and most of it says that the Tour and the Roaster both have the same engine. So since I own both of them I thought you all might be interested in the Dyno results. I put a PC111, K&N air filter and D&D pipes on the R111T and the same thing on the R111R except I used Triumph off road pipes. Then I had each of them put on the Dyno. The R111T started at 92.8 Max HP and 137.89 Max Torque and after the changes ended up at 101.52 Max HP and 146.91 Max Torque. The R111R started at 122.85 Max HP and 145.05Max Torque and after the change ended up at 130.39 Max HP and 151.72 Max Torque. This all makes me think that there is a major difference somewhere and I know there is a lot of how and what to do to increase the HP and Torque of the R111T. I guess what I would like to know is if the engines are indeed the same then why can’t we just use the Tune from the R111R and put it in the R111T which would give everyone what they are trying to get. I know this will sound stupid to those who really understand why this won’t work but I sure would like to know anyway.
Note: If you think these Numbers look a little low the set up was done at over 6000 feet above sea level
Trapper
Trapper
