Quick shifter installation
Bikefalcon
Standard Bore
2023 rocket 3r, ktm SDR 1290 evo, triumph speed 40
Has anyone installed the quick shifter themselves? Where does the electrical plug in? Does the dealer have to activate it?
The dealer has always had to activate it in the ECU, however I recently learned that the latest version of the DealerTool software v6.60b added the capability to turn on and off the quick shifter. If you've already got the DealerTool OBDII cable, updating the SW may give you everything you need to enable the TSA. The calibration procure seemed pretty simple, just running up and down through the gears in a sequential way (can't remember where I saw that though).
http://dealertoolcouk.ipage.com
I had the dealer turn mine on. It will depend on if the actuator is in compression or extension to shift up in the gears, it's different between a GT and R model.
