I have a 09 R3T that pulled to the left sharply when I removed my hands from the bars. It wasn't to noticeable with hands on the bars. I jacked the bike up by the engine only with a motorcycle jack. Then I loosened all engine supporting bolts and then retightened them evenly.This completely solved my problem. At 65 mph I can remove my hands from the bars and the bike tracks straight. It's worth a try and it didn't cost a thing. Less than one hour total.
SIdecar Flip,
I hate to disagree with you, but will on a couple of points..... I quote "Weight to one side won't really effect the steering because you naturally shift your body to compensate, it's called countersteering...."
Not exactly.
Countersteering has nothing to do with weight to one side. Let me give you an example of countersteering. You are riding in a straight line and want to turn left. Rather then turn the bars to the left, you "push" the left hand bar forward (essentially turning the bars to the right which is "countersteering") causing you to turn left. If you want to turn right, you "push" the right hand bar forward and the bike will turn right. That is countersteering. Try it and you will see what I mean. Road racers use this technique most effectively. I can explain the physics of it but will pass on that for now. You can read about it in a book called "twist of the wrist" by Keith Code.
Next item, I quote....
"If the bike veers to the side riding hands off, it's mostly the headstock bearings, either preload, flat spotted or rough from corrosion internally."
No, not really. I have ridden many an older triumph with flat spots on the steering races. You will feel a notch but you will also find the flat spot is mostly centered. There are physics to explain this as well. Corrosion will not cause it either. His issue has to due with frame/wheel alignment. Other causes may be tires or.... an uneven road. There is a road by my house that when you ride down it you will swear your bike is pulling to one side. It is a small rut made by many many cars traveling over the same area and the tar has leterally, sunk to form a small rut. You cannot see it when traveling at highway speeds, but you sure can feel it.
Try this: at 10 to 15 mph let go of the bars and see if it drifts to the right. Speed up to 40 and let go and see if it pulls left. If so then you wheel alignment is bad. Since the rear is locked in place because of the drive shaft the problem must be at the steering head. Since the bike uses a sub frame (the engine is the frame) the upper section could be skewed enough to misalign the wheels. What mport suggested may help.
The swing arm can have a bend or twist in it which will cause it to pull one way or the other. I have had this issue on a Ducati 900 ss SP. This effect can produce quite an unsettling feeling when on an (mildly) uneven road. I had to misalign the rear wheel to correct it. I then had it straightened at my local GMD Computrack. Steering head can also cause the problem if it is not straight. Bad bearings cause other problems (tankslappers, etc)
You lost me on sub frame. the R3 has a "frame" of which the engine is a supporting member of. A subframe is the portion that is attached to the "frame" that typically supports the seat, rear fender, etc. The subframe can either be bolted on to the frame or welded on to the frame. The R3T subframe I beleive, is welded on to the frame.
Didn't mean to confuse. The frame of the Rocket is bolted to the engine. You'll note no double or single cradle down tubes to support the motor like on most other bikes. The engine is a stressed member and the frame bolts to it going over the top. The double spine over the motor is supported by the motor, therefore the motor carries the loads on the bike (it's big enough to do that). A traditional "frame" carries the loads on a bike and the motor is one of those loads. That is why I referred to the "frame" as a sub-frame since it isn't the typical "frame" of most typical motorcycles. Technically I believe you are 100% correct. I therefore bow to your precision and accuracy.:)
I have the same issue exactly. a 2011 Roadster with 7.5k. It was riding true before I got new tire put on. Now its crooked in the way you mention. I don't notice unless I take my hands off and then it falls to the left immediately. the dealership said they can't find the cause but I doubt they looked as they forgot my air caps and seem to not give a **** or want to do any work especially on my older enormous bike. Why do the dealerships suck so much? I saw above someone else in Texas has the same issue as I do.
I own a 2009 R3T...got it as a left over and got a great deal on it.. love the bike I now have over 1200 miles on it..the other day going down the road I pulled my hands from the bars to zip my coat..and it pulled to the left really fast ..put my hand back on the bars got it going straight again..tried it again and still pulled to the left..now i know most are say well don't take your hands off the bar..but I have done this in safe places to fit my helmet,fix my coat stuff like that and my bikes have all tracked down the road straight & true.. everything looks good ..my one friend say its because its shaft drive???
Thansk Ed:cool:
My 05 does that only when I ride in a blue state.
