barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
I found the triple 2780 K&N worse. Just saying. If you want to mute it - the simple answer is the bearclaw from @ozrider Breathes (funnels air in to the filter area) better and is quieter. A heat shield between the filter and the undertank area helps too. Wear earplugs - you won't care then.Potentially the only thing I may do if the Ramair pisses me off is revert it back to k&n or something, big fan of induction roar but never had it that close to my head hahaha
If you decide to go the WHOLE HOG (you say no now - wait
The BIG case for a ramair over most other aftermarket solutions is that the AIT sensor IS in the air-stream - I cannot overstate enough that the RAMAIR was designed by an ex-forum member (and wicked engineer on the quiet - Heard of the Godden 500?
And - This maybe a bit of "Rose Tinted Spectacles" - but I'll swear they are quieter since switching to the Manifold (de)pression tuning method. Not monstrously but a bit.
