Oil tank temp gauges - cheap as
You must be younger than the rest of us Mick ;):D
Convert Fahrenheit to Celsius
℃ = (℉ - 32) / 1.8
or
C = (℉ - 32) x 5 / 9
Odd that the formula shown mixes decimals and fractions, I learned it as 9/5, not 1.8
Anyone that doesn't use good old red blooded American Fahrenheit is a bit suspect anyway. ;)
The one I linked is in Celsius, I prefer Celsius as well unless we’re talking weather, then Fahrenheit it is.
A quick glance down will let you see it, but, I’m more interested in seeing this for oil weight reasons.
Here are the measurements in my stock cap.
As a black one this one should work, measurements are very close, ordering, will verify if it does or doesn’t fit.
Black Oildipstick with Temperature Gauge for Harley-Davidson 1979up Sportster Softail
Good find!
This appears to be similar and same fitment as the one @1olbull bought so if your right it will fit the Rockets as well as the version I got.
Black Oildipstick with temperature gauge until 140 C° Celsius. Fits Fits Harley-Davidson® Sportster models from 1979 -2003 and Softail models from 1984-1998.
MORE INFO
Dimensions: Total length 10,5cm, top diameter 4,0 cm , measuring rod length 6,5cm, plug diameter 3,3cm. Fits Harley-Davidson® Sportster models 1979-2003 and Softail models from 1984 to 1998.
Ya, & report on that too please :thumbsup:
Agreed with the first statement but not the second Celsius is MUCH easier to work with and far more logical. Freezing is 0 and boiling 100 vs -32 and 212 WTF ;):p:D
I made up the second version after reading the top formula online and who the heck can divide a 2 or 3 digit number by 1.8 quickly in their head - not me! Obviously for the calculator only user!
But break it down with 4th grade math into easy head calculations and I got:
Which seemed awfully familiar and easy to flip the conversion the other way..
according to my calculations i would shut the engine down at 240 degrees and that would be at 115 degrees c
the red line starts at 120 c and at 248
i would be curious at what temp our oil starts to steam (for lack of a better word)
i put trans fluid on a camp stove (in an open area i know not to bright) and at 250 degrees it started to break down, that was a long time ago and it was not synthetic.
I have cousins my age in England, they were just the right age when the switch came that they can think in Fahrenheit or Celsius equally, without actually doing the math.
