O2 Sensor eliminator
Stan
BigPapa351
Melbourne Australia
Rocket 3 GT
Hi All
I have a question re: 02 sensor eliminator.
I'm looking at getting an A.M slip in and it doesn't come with the plug to screw the original 02 Sensor.
So I was wondering what has been done to overcome this issue.
Is there an 02 eliminator available, is there a tune ECU program to eliminate or gotta buy a weld on plug for the slim on?
Thanks in advance
I haven’t seen O2 eliminator plugs for the new rockets. Not sure the old ones have the same connectors or the right electronics.
You can remove the sensor but you need to use Tuneecu to suppress error codes by disabling the O2 sensor error codes in the tune.
P.S. Uncheck the O2 sensor box in the parameters/devices list in the maps tab in Tuneecu. This doesn’t disable the sensor but it suppresses the CEL/error codes. This worked fine on the older models. No sensor, no closed loop. Not sure about the new models. It would be nice to hear from someone who remove the O2 sensor.
Hi All
Thanks in advance
Edit:
disconnect o2 sensor and then you must disable it in ECU
