Neville Lush
www.nevillelushracing.com
- Joined
- Feb 26, 2007
- Messages
- 1,038
- Location
- Victor Harbor South Australia
- Ride
- Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki
Clean all the silicon and crap off of everything, head, valve cover and gasket. Get all the tubes of silicon and give them to a plumber, thats what it is for , plumbing. Put a thin smear of three bond 1211 in the D's of the head, a smear about .005" thick. Then place the clean dry rubber valve cover gasket into the valve cover. Hold it in place with a SMALL drop of superglue every couple of inches around the gasket, and two or three little drops around the spark plug rings. Carefully lower the cover with gasket attatched onto the head, locate the D's as you lower it down. Let it sit and look all around with a torch and see if the edges are all inplace. Then do up the bolts. Maybe to a practise install without the gasket a couple of times, so you get the hang of which way to put the cover on. See how you go with that. Good luck.
