W. Tripp
.040 Over
W. Tripp,
do you think a system could be figured out and worked ? I know nothign about NOS..
and more importantly, would this be a better alternative, or shoudl I just pony up the cash for a set of Nevs cams, or keep savign my pennies for a Blower ??
And yes I realize a good used busa or similar is the best way to go drag racing....
Yes, it is fairly easy to set up a safe nitrous system, especially if you are only looking for modest gains - 50-75 crankshaft hp with a full bottle (less as the bottle pressure drops). Compared to the price of cams and/or supercharger, nitrous comes out ahead, but they can't really be compared (apples-to-oranges). If you are happy with your current power on the street and only want more at the track, N2O is a good way to go. If you want more on the street as well, you may want to pill down the nitrous for the street, and use larger pills (jets) for the track.
All it takes is a call to a couple of the better known suppliers. You can buy a full kit, designed by a single supplier that will customize it for you. Or you can buy different parts from different suppliers.
You will have to mount the nozzles, solenoids (possibly fabricate mounts), and do a bit of wiring and tube routing. The biggest issue will be tapping into the fuel line, but this is nothing big. You will also need to decide on how large of a bottle you want and where you can mount it. Sometimes it is easier to use two smaller bottles than one larger one. If you are willing to use a system that shuts down if the throttle is not open 100%, you and drill and tap the adapter under the throttle bodies to mount the nozzles.
I would suggest staying away from aluminum nozzles (they crack under vibration) and going with stainless ones from Edelbrock or Wilson. At this power level, the Wilson V-force nozzle is good and will come on smoothly. Nitrous Express has some small and light solenoids for bikes that work well, and I especially like their progressive solenoid controller for use with bikes, but the last time I talked with them, they still did not offer stainless nozzles.
Stay away from hard lines from the solenoids to the nozzles, and use the hard plastic tubing that comes with most kits today.
N2O bottles are nothing more than fire extinguisher bottles with a high flow valve and a tube that feeds from the bottom of the bottle. (no tube is needed on small bottles if you mount them inverted. If you can't find a size you want, it is easy to order a valve from a nitrous supplier and mount it to a small fire extinguisher bottle. Carbon wrapped bottles are a bit lighter than normal bottles, but cost much more. The small carbon-wrapped bottles for bikes and snow mobiles (sleds) can cost as much as the large 12 pound carbon bottles. You will want a spare bottle (or spare set of bottles).
If you buy a kit from a supplier, throw away the cheap relays that come with the kit and buy some good ones that are fully potted (water proof) like those from Bosch, Hella, etc. Or go to the new solid state relays that cost more, but are incredibly fast and reliable. Make sure all of your wiring is done with heat-shrink connectors (not the cheap ones with PVC covers).
Buying nitrous from speed shops is stupidly expensive. If you are not going to go through enough N2O to warrant buying a mother bottle and filling station from a gas supplier, find a local racer with this equipment and work out a good price. Make sure your bottles are completely empty and have been chilled overnight before filling. Weigh the bottles before and during filling. At the track, keep the bottles warm, but not hot - especially between runs.
http://www.edelbrock.com/automotive_new/mc/nitrous_systems/nitrous_main.shtml
http://www.nitrousexpress.com/power_sports/home.htm
http://www.wilsonmanifolds.com/content/view/17/35/
There are other suppliers as well, but these I have experience with.
And remember, do not call nitrous "NOZ". This is a Hollywood term that the 'boy ricer' crowd uses. It will set you up for paying stupidly high prices and getting strange looks (and rolled eyes).
IF you decide this is something you are serious about, I can help. Send me a PM and we can talk via phone. If you want to get really serious, I have a friend that makes annular discharge wet and dry nitrous plates for bikes, that leave nozzle spray patterns (and performance) in the dust.
