New Rotrex C38-91 Supercharger
Steel R3 cam chain guides with Delrin inlay... no flex, no break @ highest spring pressures.
Walt, I so like to see that table, or more accurately the goodies on it, did you source them or get them fabricated to your specs ?
Glad you like them, Les!
My concept, my specs, executed by my excellent machinist.
This thread is now officially re-named "New Rotrex C38-92 Supercharger".
So what exactly is the difference between the -91 and -92 blowers?
34 RWHP
ceramic pistons and rods
Hombre, is it a complete set, ceramic pistons with the (carillo?) rods ? And don't the cams to be changed ?
Will you inform me where I can buy those parts? Thanks !
The parts used in #9797 (pistons, rods, cams, and C38-92 blower) are not a kit, and cannot be bought as a package. Make sure you thoroughly understand the relationship between pressure ratio (boost pressure), static compression (piston compression ratio), and dynamic compression ratio (cam lobe spec & LSA) before you decide on pistons and cams to install in a maximum boost supercharged Rocket3. Superior inter-cooling and proper fuel grade are necessary to prevent detonation.
You can source JE ceramic coated turbo pistons in Europe here: PMI Europe. - Homepage
Carrillo rods for the Rocket3 can be sourced from UK Carrillo distributor: Performance Unlimited - Carrillo UK distributor
This is SOOO out of my league but I am just curious whether the stock trans and rear end can take this kind of power. Were any mods done in that respect?
If not, I've gained some enormous respect for the driveline setup.
crank driver TTS
Hombre, I have the same problem with the crank driver. It's partly broken and leaking.
Is it possible for you to deliver me your version of that part ?
Tnx !
