sonny
FIXED. White and blue wire at relay socket had a worn spot in insulation. Apparently after removing and checking everything the worn spot was up against the frame.
splice a little extra wiring in and soldered it all. Covered with heat wrap and electrical tape. Also had a piece of electrical protective coating and spliced that so i could fit it over all the wires leading off of the relays. Thank you @DEcosse . A weeks worth of trouble shooting and it is finally done. Lights work, Fuel pump works.
