Need Help Bike won’t Start
rogersau3
Standard Bore
Lyons NY
I have just finished a bunch of wiring and changed the battery. I tested everything and had the bike running for about ten minutes and then shut everything down. A couple of days later I could not start it. When I push the start button it will not roll over. Everything comes on and the starter engages but then disengages and the Speedo resets again. When I was hooking up the battery I heard a noise like something cycling under the tank but I ran the bike after installing it. Could it possibly be a computer reset of some sort??? :(
Check your positive and negative terminals, make sure it's tightened down properly.
Put a charger with a 50 amp start circuit on it and try to start it. If your new battery has a bad cell the amps will peg high (and it still won't start).
Hay thanks for your help it was just the new battery. I just didn’t want to believe a new battery could be the problem. I took it over to test it and nobody could so I got a new one and works just fine now. I immediately thought the worst instead on what made sense. :roll:
