Need ECU help!!!!!!!
Thank you for this. I have read so much today that I will sleep on it and give this a read tomorrow. I miss the aircraft, where it was just a click fwd or aft on the fcu then do another engine run!!!!
Other then balancing the throttle bodies while the engine is running all the adjustment on other things like the tps, stepper motor are done with the engine off and key plus the on off switch in run position. Same with the other various test on the test page.
I have figured this much out, thanks, but tomorrow when I adjust the throttle bodies, which figure do I use as a base?
I can't gain access to the other checks with the bike off except fan, fuel etc.
I have thought about deleting all and starting over again? Thoughts??
Hi all, more help please. Cable turned up and downloaded everything but won't allow me to make adjustments?? Here are some pics and you'll see the throttle bodies need tweeking. Any help would be greatly appreciated
Muff
Which cable did you buy?
Use the middle or 2nd throttle body reading. Adjust 1 & 3 to match
