Mixed Emotions
The guys I ride with are a little more... um "reserved" then I am. So the worse I have done even with the VTX was 2nd with these guys.
It has been as I am sure you know raining here for 40 days and 40 nights, so we have not gotten out much.
I did order the cable for the TuneECU, and the GIpro today.
I am not sure I going with the TuneECU but figured I would at least look into it. I had a powercommader on the VTX so I am use to that, and will most likely go the same route Hellfire has gone. The combination of PC and GiPro...
I have a few things left with the house before I can start looking at the exhaust, but the rest of the goodies I should be able to gather up and be ready. I still have to decide on exhaust and I have no idea what gives the best bang for your buck. On the VTX it was pretty limited on what exhaust actually gave a performance boost and I am not sure what the performance exhaust options are for the R3. So I have some more research to do.
Part of the benefit of the GIPro is you're one button away from factory settings or enhanced performance. Sort of a poor mans fly by wire. Conditions change (wife on back) and you adapt performance to suit.
I've kept my intake and exhaust stock, so for me it's a cost effective solution. Others want a lot more umph.
That's right. Some want to plug and play and others want to plug and play with it. I prefer the plug and play. Install, flick a switch, turn a screw and off you go. Love it!
Three cylinder English Spitfire aircraft sans machine guns, working on pod mounts now. No wife, no home, no worries. JR3W Searching the roads for the Red Baron in his VW
If you've ever been caught in the rain with the wife on the back while still running a Metzler, being able to push the button on the GiPro to go back to reduced low gear power is a big confidence boost. Removing or opening secondaries 100% and programming the ECU for full power in low gear is fine, but try to de-tune the bike in a down pour on the side of the highway while the wife is complaining.
GiPro lets you put it back to stock or just limit 1st gear power with a pen. It's almost like push button traction control.
While I have yet to ride the bike since making the changes early this morning, my ECU cable showed up Saturday so last night I used TuneECU to open up the secondaries to 100% at all ranges.They were quite restricted in the factory default settings.
I also copied table I4 and over wrote tables I1-I3.
(I did save a copy of the default map before making changes)
Will report on any new emotions these changes bring out.......
OK.... Now I'm impressed!
The bike I pushed outta the garage this morning was a hell of a lot different then It was when I pulled it in last night.
Throttle response is much better, there is still a lag, but it is much better. And so is the power! What a difference there is in the power. OH I am going to be in so much trouble with this bike!!
