barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Define Handling!.is there a substitute tire for the Touring that will be better handling that will keep ABS happy ?
A narrow low profile tyre will give you quick precise cornering but will require better suspension as the tyre will flex less, thus not absorbing mini-bumps. They are also less forgiving if you mess up. Go too far and a steering damper mey become a requirement. Scott was maching the Falcon to fit a Radial Damper - but the Falcon is rather special at 450bhp.
Wider high profile are far more forgiving when Mr F*ck Up comes to visit but because they flex more the steering is less precise. It is however much less fidgety (in general).
Also (iirc) a radial tyre footprint widens and shortens when compressed whereas a Bias tyre footprint lengthens and slims. You need to know where you want stability. If banked over - probably radial. If on big bumps straight line (gravel/dirt roads) more likely Bias.
On "T"s I'd suggest starting by doing something with the forks. Unlike the USD's on standards there are Cartridge emulators available. made by RaceTech in the US. USD 115 on US Amazon.
My local suspension guy was testing them - They are NOT going to replace a new bespoke set of cartridges - but improved hydraulics of the Yamaha he was testing on.
I'd suggest you do NOT leap down the tyre size table - but try step by step. So if you have a 150 now - go to a 140 and maybe drop a profile - I'd be reluctant to go UP a profile - but because I premium cornering.
