warp9.9
Pocałuj mnie w dupę
Hey all...well, I have an 05 RIII Classic with 7600 miles on it that has been stored on a stand but started periodically for the past 18 months...the last 3.5 years I've been deployed and the bike only came down a couple of times over that period. Sadly, I noticed a rough-feeling, almost a scrape, as if the starter was engaging while riding at low speed that is most prevalent around my right front foot peg...I now notice the infamous paint can rattle and can duplicate a sort of bearing squeal type noise rolling normally on throttle in 1/2nd gear between 13-2200 rpm. I'm certain it is the same culprit. I just tried rocking the bike back and forth in gear to kick the tensioner over a tooth (another site points to this as possible remedy), no joy. I've already spoke with Peter (James actually) in GA and explained what I hear, feel, and what I've read. I didn't get any promises and was informed that these sites are not endorsed by Triumph (why would they be-bunch of honest people posting honest problems?). Anyway, he said take it in, let the dealer look at it, and have them contact TC-hope it works out. I'm a wrench (Army helos) and half-tempted to do the work myself although my time is limited. I am filing a complaint with the NHTSA in the hopes that they recall this thing before someone gets hurt. There are a LOT of people out there that have had horrible troubles with this and thankfully have not been hurt yet. I am disheartened as I LOVE the bike and don't make a fortune to pay for maintenance. I was so excited to have it paid off, now I'm nervous...I've printed out pages from this and other sites hoping it will help with Triumph's decision to cover my out of warranty barely ridden $16K motorcycle....thank you all for the info.
JW are you sure yours is a 05 ? if so it is not a classic as they did not make them until 06. In 05 there was aproblem with the crank gear. I believe it was a heat treatment issue as the keyway got sloppy causing the rattle. Triumph changed the tensioner guide in 06 from the aluminum to a black one with steel backing on it and for some reason went back in 07 I believe if not 08. The update kit changes back to the aluminum guide. I think what happens is the chain gets loose and start banging the duides and the tensioner which creates the slopp in the keyway. Another cause could be loosing tension on the tensioner eioth by the plunger kicking back or the end og the guide getting screwed up from puonding the tensioner when there is slack in the chain.
the two different styles with one aluminum piece that failed
not the failure below
below is the culprit
the chewed up end allowed the chain to whip and bash the guide which cracked it in the center.
If your a wrench you can do the fix easily in 4 hours. If Triumph is going to foot the bill which it sounds to me like you struck up a good conversation with them, so I would let them fix her if they are paying for it.
Triumph corporate does watch these sites and they also have great memories especially when it comes to doing warranty work out of the warranty period. Depending on one communication skills is directly proportional to the amount of help you get from them. Trash them on these sites and help is not as readily available when your out of the two years warranty period.
Some people may not like this but is is the truth you catch more flies with sugar then manure. Triumph does not endorse these sites do to liability factors. You get guys on here that are new and swarms of people try telling them to switch to car tires and other various things that Triumph will not reccomend. I can not blame them either, as they most likely take everything posted on these sites with a grain of salt.
Good luck and if you tackle the job yourself and need help let me know I have torn into mine many times latley just to dial up new cam settings. Its a fairly easy job and the only specail tool you will need is the cam alignment tool.
