Looking to buy a R3T, few questions.
rahoffman2
.060 Over
Grand Haven, Michigan
2008 Rocket 3 Touring
I'm thinking of moving up to an 08 Tourer from an 02 Honda Shadow Sabre. Going to look at it Friday.
Are there any specific things I should look for? Do most of you pull your own maintenance? Are parts and accessories easy to find? Are there after market exhaust pipes available that are louder?
I've only ever had Honda bikes and Triumphs are the great un-known to me. Any info would be appreciated.
Thanks,
Rich
Thanks,
Rich
Hang on really tight!
Don't look, just get it and don't look back. There are a few that do their own work but I don't. Minor stuff maybe like, rear wheel removal, brakes, throttle adjustment, cat box switch out, but no mechanical or electrical, maybe a horn with help. After almost 5 years the only part needing replacement excluding tires, was a clutch cable.
Accessories:
You won't find a lot in the way of after market accessories, not compared to what is available for Harleys for example. I don't know what the after market availability for Japanese bikes so can't really give you a comparison there. I'd recommend doing a search of the usual suspects to see what's out there. Triumph has a bit of bling/accessories for the Rocket, no where near what they have for the Thunderbird, however. There are over a 100 Triumph accessories for the T-Bird including 2 different TOR slip-on pipes, lots of bling, etc... They really only missed the boat with the horrid looking sissybar. They basically used the same design (MASSIVE) as the R3T unit. It looks fine on the R3T, but the R3T is a "touring" bike. That big honking thing looks hideous on the T-Bird, IMO. At a minimum, Triumph should've at least offered one smaller (more slendor) unit for guys that don't need/want the large touring unit. The R3T stuff from Triumph is again, limited, IMO. There are 2 different shields, one TOR slip-on pipe (not much louder than stock) a couple of different seats, one sissy bar. The engine guards, light bar, taller shield and sissy bar now come on the bike (didn't when I bought mine). There are a couple of different mirrors and a few other bit of chrome bits/bling here and there, but that's about it.
Maintenance:
This is *my* experience. You won't need to worry about maintenance because the bike will be in the shop for warranty repairs so often that the dealer will likely feel sorry for you and get Triumph to authorize maintenance work while they have it. Here are the issues I had with mine within the first year of ownership.
- Loose (poor design, IMO) mirrors from day one (useless due to blur)
- Blown Head gasket replaced under warranty at 5000 miles (this problem is WELL documented on this forum)
- Tires replaced under recall at around 5500 miles
- Gear Position Sensor replaced under recall at same time as tires (another well documented issue)
- Shift lifter shaft snapped in half and replaced under warranty at around 6000 miles
- Valves suffered from "bucket stacking" from day one. Nothing done by Triumph as it wasn't considered harmful to the engine, just an annoying noise/rattle. My dealer confirmed that it wasn't harmful, just an annoying sound
- Clunky transmission from day one. This got better after the first oil change, but it still shifted like a log wagon compared to any other bike I've owned.
Those are the things that I can think of off the top of my head. Frankly, I probably forgot some. A common issue with the Rocket that, fortunately, I did NOT encounter with mine is the high idle. And of course, there's the dreaded "paint can rattle" that was supposedly fixed on later model Rockets, but I still hear of guys with later model bikes that have that issue. I've owned probably 25-30 bikes in my life including MANY Triumphs and the 08 R3T I had was by FAR the most "issue" prone. The head scratcher is this is supposedly Triumph's "flagship" bike. I've never had an issue with any my other modern Triumphs. Of course, everyone had issues with the Lucas Prince of Darkness Triumphs of old.
That said, having the "issues" is not the main reason I got rid of it, although it certainly made my decision much easier. I got rid of it mainly because I could never get comfortable on it. I'm probably smaller than the average guy at a 150 lbs, but my height is average at 5'10". I could never ride the R3T for than 40-50 miles without getting neck and shoulder pain. I bet I re-positioned the bars 10 times if I did it once. I installed new risers. I tried different seats including adding a rider backrest with 6 different adjustable positions. Nothing worked. I got tired of fighting it and bought a Thunderbird. That bike fit me like a right out of the box. I wouldn't dream of changing anything to do with ergos on my T-Bird. That's just food for thought. It is a MASSIVE motorcycle and the seat, bars, etc... are all wider than anything else you'll get on except perhaps a Boss Hoss.
Anyway, just food for thought. You need to really pay attention to the ergos and do not fool yourself into thinking a 5 mile demo ride is going to tell you much in that regard. I'd highly recommend trying to secure a 40-50 mile ride on one if possible.
On the good side, the beast will pull a freight train as long as it has traction. It handles pretty good for such a large bike. And, gas mileage isn't too shabby for such a large engine. I got a pretty consistent 38 mpg on mine. Of course, if you twist the throttle hard and frequent, you can expect that number to drop dramatically.
Good luck with your decision!
I wouldn't hesitate to get a Triumph. Consider the Roadster. I agree that theres not as many acessories as other manufactures, but enough for you to spend some cash.
Hi Rich nice to here you are looking at a Rocket, I have an 07 Classic Tourer bought new in May 07 have 40k on her now, traded in a Honda Shadow Aero with 50k and had been riding Hondas since 85 and love them, wife still has the VTX 1300. Here are *MY* views on it.
Love it love it love it!!!!!
Mods: have done are cat bypass, the GIPro, trailer hitch and gone to the "darkside" (car tire).
Problems: fast idle last summer which Tiumph covered the part but not labor (had 34k on it). The loose mirrors I fixed with a aluminum can just took mirror off and made new thicker shims and put back together no problems since. Starter button acted up a couple times last summer, pushed it nothing happened, did just a couple times had to push it 4 or 5 times to get it to start. The leather saddle bags (difference between Tourer and Touring) the top piece of leather shrunk and pulled the seams apart. Took them off.
The part the dealer had order took about 10 days to get but was still able to ride so not to bad. The cat bypass I bought online from a dealer that had it in stock, got it in 2 days. Ordered brakes and they were here in week.
On here you will read about the battery and how people hate the stock battery and the only thing i can say is that i have the origanal battery and have had no problems.
Overall no complaints.
As long as Triumph makes a Rocket III I will never own anything else.
PS Did I mention that I Love It!!
Welcome to the site. You're doing the right thing in researching your proposed purchase.
Moving up from the Sabre is a good jump in power and weight. The Rocket is a remarkably well balanced bike and is easy to lift off from the side stand. However, you have to remember that it weighs almost double what your Sabre does. That almost makes it very stable on the road.
RocketDaryl has been around this site for a long time and while he certainly had a problem bike, be rest assured that his experience is far from typical. Yes, some of the early models had teething pains but most of the issues had been worked out by the '07 model year.
Since I prefer to do long-haul touring, I wish that I had the Touring model rather than my 06 R3 Standard. I've invested alot trying to make it into a tourer but that's not what it is built for. I've demoed the R3T several times and really like it. Once you crack the throttle open on a highway on-ramp, you'll never look back. Or, accelerate out of a corner going up a mountain without downshifting, you'll understand. The power is incredibly additive. And for such a large bike, the gas mileage is very, very good and it runs on regular gas (seriously, don't run premium. it doesn't like it.)
I have an 08 R3T with just a bit over 20,000 miles. Gear position sensor replaced during service due to recall although it never caused a problem. Bridgestone tires replaced under recall as well. They did cause a problem. I had the heated grip throttle control break leaving me stranded. I've heard others have had this problem as well. I would not install the Triumph heated grips.
Other than that I have had no problems. The bike has been modified to deliver power equivalent to the Standard/Classic models and is very comfortable to ride. 500 mile days are easier to accomplish on the R3T than on the last 3 BMWs I owned.
Hi, I have a 2010 R3T, I bought it in August and still managed 5400 miles, no serious issues, both mirrors wouldn't stay tight, dealer added crush washers, no problems since. Fair bit of vibration in right mirror only, for some reason, smooths out over 65. Pinch bolt fell put of shifter link first day I had it, LOL, it was stripped, dealer replaced shifter.
Starts in 30 degree weather after a month in the barn with stock battery, no tender. No mods yet, may go with different pipes and a tune, but plenty of power as is. Heavy at 860 lbs, but with the low center of gravity, and the highway bars, I can set it down on it's side and pick it back up unassisted. Great bike, I'm a happy owner.
