Little help with outlaw pipes please
Your local dealer is having you on . The cats on a 2014 roadster are in the pipes , which is why people fit the Tors. If your having problems with the idle and your making smoke , then you need to be looking at a tps , iscv check / reset ! Easily done with tune ecu . If these settings are all to buggery it will explain all problems you are having . If you have run the bike for 20 mins or so there would be nothing left to burn off . Besides , oil burns with blue smoke whereas an over rich mixture which would almost certainly be caused by base settings being awry , burns with black smoke !
Can't seem to upload any more pics. But the CAT on my tors was still on the cross piece
That box huffa is not the cat . It is more or less an empty box designed solely to disrupt the exhaust flow and so stifle the power . Most people when installing tors, also fit the link pipe for a free flow !
Is that definitely a tors ? If so , it will have a full 50mm outlet hole and a use off road only stamp down near the mount !
That pic is of a stock roadster can. Not a TORS. Never seen one rust like that tho. And they have as much steel in them as a battle ship.the pic shows what a TORS end looks like.
Definitely triumph off road pipes
Mine looked like that 40000 miles ago
Didn't know that cheers. It does sound like my local dealer is having me on
