I’d like to have dual function, safety first, maybe @DEcosse will see this and know if dual function would work or not, if not the Harley led I posted in picture where I said this is what I installed do work well. (With resistors)
Question: where did you put the resistors? Trying to picture it...
On side at turn signal connectors,(the white ones) one is for right and one is for left, I went to rear of those plugs for my install
:D:D
It's normal to remove a few panels or parts to modify your bike, but isn't this extreme to fix the turn signals
Engine is in Seattle, all bearings/ all cables/ electrical upgrade Fuzeblocks brand/ rebuild calipers/ handlebars swap/ forks rebuilt with emulators/ just going through a couple things to make safe as I can trying to get to an airstrip to run this spring. Haven’t even scratched surface of rules for that/ kill switch/ fuel off valve/ safety ties a lot/ steering dampner/ it’s winter down south here in Nashville so it’s a good time to tinker. :D
:D:D
Tinker! I would say a heck of a lot more than a few changes. Who's putting the wings on "it". Kevin you have a serious project going on. Impressive.
I agree with you, safety first, especially with today's population of distracted drivers.
It looks like you have purchased the 1156 (per your link) Kevin - 1156 are single function so only work as Turn Signal lamps.
To get the running lights option you would need 1157 version PLUS new Housings with dual connection capability (3 wire)
(RRI also have a housing available - two options with slightly different mounting - plus also a clear or smoked lens (so the LEDs are not behind the supplied yellow lens).
Then for the 3-wire connection with dual Running/Turn capability, you would simply connect the Turn Signal Wire and Ground to the std turn signal wires and then the Running Light wire would be tied to the Park Light circuit (yellow wire on bike harness)
Thanks for that I believe I’m gonna go ahead and look into making this upgrade. You are the man and I am so appreciative for all your help this year, getting me back up and running in several occasions and making the widow maker better than ever before. Gonna send you a picture after I install the fuzeblock and make it more professional. Thanks bud
That is why i spent the money ;););););)
