LED turn signal install advice please?
I want to install LED turn signals on my 2016 Roadster. I dont know if I need to install a load resistor and if so what size ( resistance ) to buy or a replacement relay ( I dont know what the difference is but I found a post about it). If I am only replacing the front ones and leaving the rear bulbs stock do I need to do this and if so what to do?
Thanks in advance for your advice
a few pics of my now LED equipped Rocket with OEM indicators removed.
Before I go tearing into something and maybe breaking it :eek:, would a Captain mind explaining how the turn signals (or indicators) come apart to execute the "wire switch" for non-functioning LED's? Or does it get done in the mini-harness up by the ECU?
As always, thanks in advance for the wealth of advice available here!
Take lamp apart n switch wires there
Once you have removed the lens (noting the screws are different each side) you need to place a small screw driver in the slots and rotate the inside reflector fitting to release it and access the wires.
