charlie farley said:
got all the bits to do the single really mod
I'm sorry to seemingly discredit the original poster (discredit is not my intention):
Using a single relay is a throw-back to 1960's wiring where everything went through a single switch - back when bikes had no-where near the loads they do now.
If you have capability to add ONE relay, you have ability to add multiples and keep the circuits isolated per the original design.
As I pointed out earlier in thread putting everything into a single circuit means that you can possibly shut entire bike down if a problem happens in one circuit.
...Now take ALL of the other wires and combine them together in any fashion that you can so that they are all the same continuity and take a single wire from that bundle to the 30 pin or spade of the auto relay. I made a splice using multiple butt splices down to a single conductor like a "cat of nine tails" but there are crimp style connectors at the parts houses that work better for this.
However if you DO insist on using one relay (or regardless, even if using two) then there is no need to add the orange/red & orange/blue wires into the relay circuit as per original suggestion - these two wires can simply be connected together. The only reason they go through the switch to begin with is because of the 'Park' position feature - if switch is removed (or that position never used) there is no need to go through the relay. And besides, connecting them into same pole as other wires (again, as per original suggestion) defeats the possibility of the park position anyway.
So whichever relay plan you use, these do not require to (and should NOT) be connected into the relay.
But I strongly recommend using at least a second relay, where the 30/87 contacts are for the Orange & Orange/Green- Black/Blue wires.
Also - if key-switch is still functional, no need to cut the wires out of the key-switch connector, just tap onto the wires with Positaps - then either Key OR remote can by utilized without having to remove it or cut wires from connector, further, preserving integrity of original wiring.
