fat frank
I understand the timing is different on the Roadster.(2010 and up). The peole who have altered there timing to unrestrict should have tables to use. Yes, If you use the tuneecu t unrestrict and open up the bike, you can then use the PCV to change your A/F ratio. I don't think they make the autotune feature on that year bike.
If the PCV comes dwith autotune for that year, you can program your desired A/F ratio in ad it will automatically start to maake changes to get it right up to a 20% increase in fuel. You then load that info from the autotune into your PCV and you can do it all agin till you get it perfect.
Good luck
Good luck
