i bought my bike with jardines fitted and a kn filter replacing the stock filter,the bikes been remapped on a dyno but it pops and bangs on the over run and i find it stutters a bit a low revs which is a bit buggy when in slow traffic,will a pc11 cure the problem as it seem most dynos in the uk are dynojet,cheers :?: :? :twisted: :shock:
loading of the right tune should sort most of the farting - you can use tuneboy (imho a better product) for this. depending on where you live, there are tuneboy tuners - however I think that you can convert pciii tunes in to tuneboy to load in to the ecu???
I used to to that, but I ran a TuneBoy tune one time when I had 89 in it and now it doesn't like 87 any more: "searching" idle and stalls at the ends of freeway offramps and other "dragstrips". Tuneboy is really remarkable.
If your happy with your tune, but want to get rid of excessive overrun popping, changing the L table figures on the bottom row to around 610 ( if they on zero initially) will reduce most of it. However thats Tuneboy....
Cant help with pc3...
