Harry tear into it, its easy, watch your map lines, pay attention and go slow, pictures before start and you will knock it out, start by removing all duct, then install Ramair, everything is there. just pull ait sensor strait out, it doesn’t screw, watch the head when you pull it out its plastic temp gauge of sorts, push it in ramair and its about that easy, dont forget about pictures then verify, like if you accidentally knock off or damage a map hose you may catch it, check out map lines that go to map sensor, thats maybe most important the rest will be ok, you should unplug ait, insert in ramair and connect extended cable you recieve from ramir and plug in, check clamps, check fitment, give a tug, throttle bodies right where filter connects must be correct, flashlight and look, same all the way around and clamp where it should be. You got this tons of info here to do this.
