Inexpensive replacement batteries?
Thank you for making my point.
Ever kick started an air cooled Honda CR500?
My cb750, easy peasy, at least it was 10 years ago.
I use odyssey pc 625 only rated at 220 but 540 cranking for 5 sec but will crank a lot longer.Had trouble with my 2013 touring.did the toyota replacement,still had problems with yuasa which tested fine. I had a pc 625 in my hot rodded Fj 1100 now 1314cc that had starting problems before 10.25 compression. My theory is the battery was drawing too much and taking away from coils, no starting trouble after installing odyssey. So i thought i would try it in the rocket if it would fit, it does,a little tall,can't use the strap over the top,but it can't move. No more starting trouble
I use a cheap landport gel battery for 3 years now. Very happy with this solution....costs.. about 85 euro's ( 95 dollars?)
I just replaced mine with one from Advance Auto. The previous one from there lasted 5 years and is still holding @12.9v. It's rated at 310ca and on the site lists for $110, but with online ordering you'll get 15% off. I had another rewards offer from them and got it for around $85 including tax. I see that they've since acquired the Die Hard brand and are only offering that brand now.
