im there
getting going
well the tyre pressure needs a little tinkering, im running 34lb at the mo and seems very soft with not to much roll from straights to corners.....not as comphy at high speeds , it seemed to prefer 43lb....but i will muck around with it a bit more.
i am able to scrape the pegs at low speeds with out any probs at all....not to game at any higher......but i must say very happy with it......as far as bends go no probs at all, but im always one to take it easy in this area.
Unless you are a vry heavy man those pressures seem a bit high I am 109 kg and run mine at 28psi but in saying that every tyre will be different my last one was better a little higher, just slowly bring you your corner speeds up if you start to find the bike start to wallow on big sweepers then you have gone down to far in pressure just keep expreimenting and before you know it you will be scraping at speed !!
well i bought the bike with most of the mods on it, the 3 pipes go into 1 then into the box underneith.....then 4 pipes out. i have a power com and the air cleaner is replaced by 3 air pods.
jet
jet
Great I didn't know the Mod could be done, never seen it before..
Maybe it was a home made Mod..
