I screwed up
I have used Helicoil on several applications. Especially on stripped out aluminum threads. The steel coils add considerable strength to the fasteners. You can also look at Time-Serts as another option. They are stronger and longer lasting for applications where you will remove and reinsert the fasteners with higher torque requirements.
As I mentioned previously, the damaged thread needs enough material (edge distance) to properly install a Helicoil.
Since this is a control, don’t fk around with a shady repair. As Scott @warp9.9 mentioned, take it to a pro if you are uncertain of your ability to do the repair.
Just my take. If nothing else, you’ll learn how to install a Helicoil!
Helicoil if you have never installed any now is not the time to learn. Find a machinist have him do it.
Two M6X1.0X19mm Time-serts.
At Amazon for a couple bucks each.
Better?
I just installed three helicoils on the front fender bolt sets on an old Honda project. Took about 15 minutes. A good kit will come with the appropriate size drill bit, a number of coils, and the plastic set tool.
