How to keep side trays of Speedo on all the time
Hollow Man
2023 Rocket 3R
Trying to keep the side trays on each side of Speedo to show all the time not just when I hit the joystick? In the manual it said to push the joystick in when it displays info you want, I did that and it disappears after a few seconds
Picture shows what I want to see all the time, how to make it stay? Thanks
You need to go into the settings for the theme and change the detail setting. Yours is set to Auto Hide All it seems, and it should be set to Show All. Are you saying when you scroll down to Show All and press the joystick to select it, it doesn't "take" and goes back to Hide All?
No option to auto hide or show all, under display trays everything has a check next to it
That sounds like you are in the main settings menu using the Home button on the right where you can set up all kinds of things on the bike, that just lets you hide/show info panels. So for example if you don't want Nav, SMS, Calls etc showing, you can hide them so when you scroll left and right the never show. What you are after is just scrolling to the details panel (I think it goes Contrast, Theme, then Detail as you scroll right), then up/down in the centre tray for the theme details options then press the joystick in after you scroll down to Show All.
I have the same thing as the OP. I'll watch the above vid. The owner's manual isn't much help. I've avoid "restore default settings" as I'd assumed that would reset my rider modes as well and it took long enough to get them where I wanted them.
I'm surprised Triumph were still using this dash on 2023 bikes. As far as I know it came out on the 1200 Scrambler in 2018 and it feels quite old hat now and not very intuitive.
A flat tablet-like TFT screen would look out of place on the Rocket which to my mind wants something more retro or classic looking. But other manufacturers have managed to combine user-friendly tech with style. Indian, Guzzi and Harley are all pretty good at it.
